One or more GPUSensors not ready in time
os: ubuntu 22
ros2: humble
carmaker version: 11.0.1
nvidia driver: Geforce RTX 3060
Hey, I’m struggling to run the Lidar sensor with the FS-autonomous project. I have a Nvidia driver but it keeps timing out when trying to run with Lidar and giving this error:
Screenshot from 2023-02-28 18-16-58
Thanks!
Would you be able to share which driver version you are using? Also, you are working in a VirtualBox and not a physical Ubuntu dual boot, is that correct?
Hey Bogomil,
Currently using driver version 51586.01 and no, it is an ubuntu partition that’s just the name of the laptop.
Thanks again
Apologies for the delay, I’ve been away on a work trip.
Your drivers should be compatible with the CarMaker 11.0.1 release. We used to have issues with older drivers in CarMaker 10 in the past, but those should be resolved now.
It looks like you have manually specified the IP of the host in the GPU configuration window, is that the case? Here is what the window looks like:
By default it places the hostname for me instead of an IP address, but I just tested it with 127.0.0.1 just to be able to reproduce the same log messages as you.
By default, this project has two cameras and one LiDAR RSI sensors that work off the NVidia GPU. Could you disable some of the RSI sensors and try again? We need to establish if the GPU sensors work at all. I would recommend turning off both camera RSI sensors and testing with just the LiDAR. This is how to disable individual sensors without deleting them:
If this works, then I can check how to increase the initialisation time for the sensors in case it’s some timing issue. We can also check if the ports over which the Camera RSI sensors work are open on your machine.
Hey,
Here’s a video of what happens when I try to run the project with the LiDAR RSI sensor and both camera RSI sensors disabled:
Here’s a video of what happens when I run the project with both camera RSI sensors enabled and the LiDAR RSI sensor disabled:
Hope this helps - thanks
Thank you very much for that. Yes that helps, your cameras clearly work, but the LiDAR is experiencing problems.
I need to consult my colleagues internally. I can see some internal issues that have been raised in the past when it comes to lidar/radar RSI sensors. These have been fixed in CarMaker 11.1 and beyond, but for FSAI the project was created for CarMaker 11.0.1, and I’m not sure you have access to updated CM versions.
I’ll get back to you when I get some more information from my colleagues in Germany.
I’m going through some internal information that we have on other similar GPU issues.
Could you try one thing when you have some time.
Could you go to ScriptControl and use the command “set ::Sensors::PipeConnectionTimeout 60000”
That increases the timeout of connection to the RSI sensor. It has helped some users, while for others it doesn’t resolve the issue.
In the meantime, I’ll try getting more information.
Hey Bogomil,
When I tried running the project after running the command, the LiDAR GPUSensor window still crashes almost instantly :frowning:
Thanks again for your help
Hello Rachel,
I spoke to my colleague in Germany who usually deals with GPU issues. He has two suggestions.
First, we need to test CarMaker without all the ROS stuff. I expect the problem is with the GPU libraries and integration, but I can only be sure if we test with pure CarMaker.
Go to your CarMaker installation folder and find the “CM” executable file. If you have installed CarMaker in the default path, then the default location of the executable is here:
“/opt/ipg/carmaker/linux64-11.01/bin”
From this location, start CarMaker by calling the executable: ./CM
Create a new project. File - Project Folder - Create Project
Open the following example test run in CarMaker:
File - Open - Product Examples (this is the menu on the left hand side of the window) - Examples - BasicFunctions - Sensors - LidarRSI_Countryside
This is our basic LiDAR demo. Try to start it. I expect it to fail, but do let me know if it actually succeeds.
If (when) the previous example fails to start, close CarMaker.
Now start CarMaker again with the following startup flag: ./CM -debuggpu
You should still be in the same project that you previously created.
Open the same test run LidarRSI_Countryside
Attempt to start the test run.
The terminal where you started CarMaker should now have a lot more debugging information on exactly what is happening with the GPU and its connection to CarMaker.
Please post the logs here so that our experts can review them.
Hey Bogomil,
The basic LiDAR demo did fail.
Unfortunately, I can’t attach a file (still a new user) so the logs are split into three sections. The first one is here below:
Terminal logs 1
TagScheduler: Updated DeviceList to ‘::oo::Obj361’
TagScheduler: Updated DeviceList to ‘’
TagScheduler: Updated DeviceList to ‘::oo::Obj374’
PrepareGPUSensorProcesses scheduling with
TagScheduler::oo::Obj369
ugrdv-VirtualBox-0 with tags ‘Device_0 Default’
TagScheduler::oo::Obj372
PrepareGPUSensorProcesses SensorClusters to schedule:
TagScheduler::RequestProcess look up tag Default
TagScheduler::RequestProcess SensorCluster ‘::oo::Obj477’ on GPUSensorProcess ‘::oo::Obj486’ on GPUDevice ‘ugrdv-VirtualBox-0’
PrepareGPUSensorProcesses rsi process ‘::oo::Obj477’ → gpu sensor process ‘::oo::Obj486’
PrepareGPUSensorProcesses starting GPUSensor processes ::oo::Obj486 in parallel
RunCmdsInteractive single line ssh=‘’ shell=‘’ line=‘/opt/ipg/carmaker/linux64-11.0.1/GUI/Movie.exe -mode GPUSensor -instance 1 -CMInstance 0 -headless -GPU 0 -debug -datapool /opt/ipg/carmaker/linux64-11.0.1’
StdoutProtocolHandler ::oo::Obj486: STATUS-15564
StdoutProtocolHandler ::oo::Obj486: >> SetAppName…
StdoutProtocolHandler ::oo::Obj486: → current: ‘tk’
StdoutProtocolHandler ::oo::Obj486: → requested appname: ‘GPUSensor_1_0’, given: ‘GPUSensor_1_0’
StdoutProtocolHandler ::oo::Obj486: License Features: (more info with ‘-licinfo’)
StdoutProtocolHandler ::oo::Obj486: SetDir: Fonts → /opt/ipg/carmaker/linux64-11.0.1/GUI/Fonts
StdoutProtocolHandler ::oo::Obj486: SetDir: Images → /opt/ipg/carmaker/linux64-11.0.1/GUI/Images
StdoutProtocolHandler ::oo::Obj486: SetDir: Textures → /opt/ipg/carmaker/linux64-11.0.1/GUI/Textures
StdoutProtocolHandler ::oo::Obj486: GPUSensor_1_0@ugrdv-VirtualBox → 11.0.1 2022-5-17 (Ubuntu 22.04.2 LTS 64-Bit)
StdoutProtocolHandler ::oo::Obj486: Movie 11.0.1 2022-5-17 (Ubuntu 22.04.2 LTS 64-Bit)
StdoutProtocolHandler ::oo::Obj486: LibDir=/opt/ipg/carmaker/linux64-11.0.1/GUI/lib
StdoutProtocolHandler ::oo::Obj486: GPU ids=0 (Display=0); Headless=1; CUDA Devices=0 EGL=0
StdoutProtocolHandler ::oo::Obj486: InitMaterialIds ‘/opt/ipg/carmaker/linux64-11.0.1/Data/Sensor/MaterialLib’
StdoutProtocolHandler ::oo::Obj486: → Using display :1.0 for .view0.gl0 (from DISPLAY env. var.)
StdoutProtocolHandler ::oo::Obj486: ----------
StdoutProtocolHandler ::oo::Obj486: Hardware (#1):
StdoutProtocolHandler ::oo::Obj486: GPU-0 at PCI:1:0:0
StdoutProtocolHandler ::oo::Obj486: OpenGL:
StdoutProtocolHandler ::oo::Obj486: 4.6 (Compatibility Profile) Mesa 22.2.5 (AMD), with GLSL 4.60
StdoutProtocolHandler ::oo::Obj486: GPU #0: RENOIR (renoir, LLVM 15.0.6, DRM 3.47, 5.19.0-35-generic)
StdoutProtocolHandler ::oo::Obj486: CUDA: 11.20
StdoutProtocolHandler ::oo::Obj486: #0: NVIDIA GeForce RTX 3060 Laptop GPU (compute capability: 8.6)
StdoutProtocolHandler ::oo::Obj486: -------------------------------
StdoutProtocolHandler ::oo::Obj486: Check OpenGL Capabilities
StdoutProtocolHandler ::oo::Obj486: → OpenGL.20 → 0
StdoutProtocolHandler ::oo::Obj486: → OpenGL.AdaptiveVSync → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.Computeshaders → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.ConservativeRaster → 0
StdoutProtocolHandler ::oo::Obj486: → OpenGL.Fbo → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.FboMS → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.FboMS8 → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.FboTexR32f → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.FboTexRGB16 → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.FboTexRGB16Depth → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.FboTexRGB8Depth → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.FboTexRGB8DepthF → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.FboTexRGBA8 → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.ShaderStorageBufferObjects → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.Shaders → 2
StdoutProtocolHandler ::oo::Obj486: → OpenGL.ShadowMap → 1
StdoutProtocolHandler ::oo::Obj486: → OpenGL.VMWare → 0
StdoutProtocolHandler ::oo::Obj486: → OpenGL.pbo → 1
StdoutProtocolHandler ::oo::Obj486: Skyboxes - DataPools = {} /opt/ipg/carmaker/linux64-11.0.1
StdoutProtocolHandler ::oo::Obj486: Parsing Skybox ‘/opt/ipg/carmaker/linux64-11.0.1/Movie/Skies/DeepNight.skybox’
StdoutProtocolHandler ::oo::Obj486: Parsing Skybox ‘/opt/ipg/carmaker/linux64-11.0.1/Movie/Skies/FujiMountain.skybox’
StdoutProtocolHandler ::oo::Obj486: Parsing Skybox ‘/opt/ipg/carmaker/linux64-11.0.1/Movie/Skies/Night.skybox’
StdoutProtocolHandler ::oo::Obj486: Parsing Skybox ‘/opt/ipg/carmaker/linux64-11.0.1/Movie/Skies/Ocean.skybox’
StdoutProtocolHandler ::oo::Obj486: Parsing Skybox ‘/opt/ipg/carmaker/linux64-11.0.1/Movie/Skies/Rocks.skybox’
StdoutProtocolHandler ::oo::Obj486: Parsing Skybox ‘/opt/ipg/carmaker/linux64-11.0.1/Movie/Skies/Valley.skybox’
StdoutProtocolHandler ::oo::Obj486: Parsing Skybox ‘/opt/ipg/carmaker/linux64-11.0.1/Movie/Skies/Winter.skybox’
StdoutProtocolHandler ::oo::Obj486: ToneMapping::ReadFile ‘’ 0:0 (curr=0)
StdoutProtocolHandler ::oo::Obj486: LoadTextures 0:0 LightedOcclusion ‘’
StdoutProtocolHandler ::oo::Obj486: LoadTextures 0:0 StaticOcclusion ‘’
StdoutProtocolHandler ::oo::Obj486: RequestGenDistMap
StdoutProtocolHandler ::oo::Obj486: LoadScene
StdoutProtocolHandler ::oo::Obj486: >>> LoadTestRun <<<
StdoutProtocolHandler ::oo::Obj486: → Testrun = ‘’
StdoutProtocolHandler ::oo::Obj486: → Vehicle:
StdoutProtocolHandler ::oo::Obj486: → Road:
StdoutProtocolHandler ::oo::Obj486: → Trailer:
StdoutProtocolHandler ::oo::Obj486: → Trailer2:
StdoutProtocolHandler ::oo::Obj486: >>> PrepareShaders <<<
StdoutProtocolHandler ::oo::Obj486: >>> LoadShaders <<<
StdoutProtocolHandler ::oo::Obj486: → Available: 2
StdoutProtocolHandler ::oo::Obj486: >>> SetupShaders <<<
StdoutProtocolHandler ::oo::Obj486: >>> post-processing Shaders <<<
StdoutProtocolHandler ::oo::Obj486: >>> LoadSceneGeometry <<<
StdoutProtocolHandler ::oo::Obj486: LoadMotionData
StdoutProtocolHandler ::oo::Obj486: 0 online:0 fname:‘’
StdoutProtocolHandler ::oo::Obj486: → current: ‘GPUSensor_1_0’
StdoutProtocolHandler ::oo::Obj486: STATUS-started-15564-11021
PrepareGPUSensorProcesses GPUSensor GPUSensorBaseProcess ::oo::Obj486 on ugrdv-VirtualBox:11021 startup finished.
Startup of all Sensors finished.
Sensor Mapping:
SensorClusterID: 0 SensorClusterList: Vehicle GPUSensor-Instance/ID: 1
SendStartupParamMsg startup GPU.Sensor.N 1 GPU.Sensor.0.SensorClusterID 0 GPU.Sensor.0.SensorClusterList Vehicle GPU.Sensor.0.ID 1 GPU.Sensor.0.Host ugrdv-VirtualBox GPU.Sensor.0.Port 11021 GPU.Sensor.0.PID 15564 GPU.Sensor.0.DeviceID 0 GPU.Sensor.0.Type gpu GeoFName Movie/.road_cache/_opt_ipg_carmaker_linux64-11.0.1_Examples_BasicFunctions_Sensors_LidarRSI_Countryside.roadgeo CMInstance 0
StdoutProtocolHandler ::oo::Obj486: StartOnlineAnim45
StdoutProtocolHandler ::oo::Obj486: TestRun: ‘’ Road: ‘’
StdoutProtocolHandler ::oo::Obj486: 0 online:1 fname:‘’
StdoutProtocolHandler ::oo::Obj486: Create Data Pools ‘/home/joe/test_project_1’
StdoutProtocolHandler ::oo::Obj486: Data Pools = /home/joe/test_project_1 {} {} /opt/ipg/carmaker/linux64-11.0.1
StdoutProtocolHandler ::oo::Obj486: Pwd = /home/joe/test_project_1
StdoutProtocolHandler ::oo::Obj486: → Testrun = ‘Examples/BasicFunctions/Sensors/LidarRSI_Countryside’
StdoutProtocolHandler ::oo::Obj486: >>> ReadTestRunInfo ‘Examples/BasicFunctions/Sensors/LidarRSI_Countryside’ ModelCheck=0 <<<
StdoutProtocolHandler ::oo::Obj486: → Named Values =
StdoutProtocolHandler ::oo::Obj486: → Key Values =
StdoutProtocolHandler ::oo::Obj486: >>> Get Full TestRun Name <<<
StdoutProtocolHandler ::oo::Obj486: → Name = Examples/BasicFunctions/Sensors/LidarRSI_Countryside
StdoutProtocolHandler ::oo::Obj486: → DataPool: ‘/home/joe/test_project_1/Data/TestRun’
StdoutProtocolHandler ::oo::Obj486: → DataPool: ‘Data/TestRun’
StdoutProtocolHandler ::oo::Obj486: → DataPool: ‘/opt/ipg/carmaker/linux64-11.0.1/Data/TestRun’
StdoutProtocolHandler ::oo::Obj486: → FullTestRunName = /opt/ipg/carmaker/linux64-11.0.1/Data/TestRun/Examples/BasicFunctions/Sensors/LidarRSI_Countryside
StdoutProtocolHandler ::oo::Obj486: Reading environment infos…
StdoutProtocolHandler ::oo::Obj486: All environment infos read
StdoutProtocolHandler ::oo::Obj486: Scene(TestRunFName.Previous):
StdoutProtocolHandler ::oo::Obj486: Scene(TestRunFName): Examples/BasicFunctions/Sensors/LidarRSI_Countryside
StdoutProtocolHandler ::oo::Obj486: → ROAD dir = /home/joe/test_project_1/Data/Road
StdoutProtocolHandler ::oo::Obj486: → ROAD dir = Data/Road
StdoutProtocolHandler ::oo::Obj486: → ROAD dir = /opt/ipg/carmaker/linux64-11.0.1/Data/Road
StdoutProtocolHandler ::oo::Obj486: >>> Executing roadutil - instance 1 roadgeo=Movie/.road_cache/_opt_ipg_carmaker_linux64-11.0.1_Examples_BasicFunctions_Sensors_LidarRSI_Countryside.ugrdv-VirtualBox_1.roadgeo <<<
StdoutProtocolHandler ::oo::Obj486: >>> WRITING roadgeo file (instance 1) …
StdoutProtocolHandler ::oo::Obj486: Current Working Dir = /home/joe/test_project_1
StdoutProtocolHandler ::oo::Obj486: CM_HOME = /opt/ipg/carmaker/linux64-11.0.1
StdoutProtocolHandler ::oo::Obj486: Exec /opt/ipg/carmaker/linux64-11.0.1/GUI/…/bin/roadutil -movie -o Movie/.road_cache/_opt_ipg_carmaker_linux64-11.0.1_Examples_BasicFunctions_Sensors_LidarRSI_Countryside.ugrdv-VirtualBox_1.roadgeo -route 0 -datadir /home/joe/test_project_1/Data/Road -datadir Data/Road -datadir Data/Road -datadir /opt/ipg/carmaker/linux64-11.0.1/Data/Road -datadir /home/joe/test_project_1/Movie -datadir Movie -datadir Movie -datadir /opt/ipg/carmaker/linux64-11.0.1/Movie /opt/ipg/carmaker/linux64-11.0.1/Data/TestRun/Examples/BasicFunctions/Sensors/LidarRSI_Countryside
StdoutProtocolHandler ::oo::Obj486: Prepare Route VehSafe id=0 1/1 path= testrun=Examples/BasicFunctions/Sensors/LidarRSI_Countryside
StdoutProtocolHandler ::oo::Obj486: → Vehicle: 3D/Vehicles/VW_Beetle_2012.mobj
StdoutProtocolHandler ::oo::Obj486: → Road: Movie/.road_cache/_opt_ipg_carmaker_linux64-11.0.1_Examples_BasicFunctions_Sensors_LidarRSI_Countryside.ugrdv-VirtualBox_1.roadgeo
StdoutProtocolHandler ::oo::Obj486: → Available: 1
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Movie/.road_cache/_opt_ipg_carmaker_linux64-11.0.1_Examples_BasicFunctions_Sensors_LidarRSI_Countryside.ugrdv-VirtualBox_1.roadgeo (road)
StdoutProtocolHandler ::oo::Obj486: → fullpath=/home/joe/test_project_1/Movie/.road_cache/_opt_ipg_carmaker_linux64-11.0.1_Examples_BasicFunctions_Sensors_LidarRSI_Countryside.ugrdv-VirtualBox_1.roadgeo
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vegetation/Birch_01_Summer.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vegetation/Birch_01_Summer.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vegetation/Beech_01_Summer.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vegetation/Beech_01_Summer.mobj
StdoutProtocolHandler ::oo::Obj486: → loaded from cache
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/TrafficDrum.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/TrafficDrum.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/Tollgate_01_2_TwoWays.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/Tollgate_01_2_TwoWays.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/Tollgate_01_1_OneWay.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/Tollgate_01_1_OneWay.mobj
Terminal logs 2
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Buildings/Guardhouse_01_1.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Buildings/Guardhouse_01_1.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/BMW_5_2017_Customs.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/BMW_5_2017_Customs.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=BMW_5_2017_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/BMW_5_2017_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/BollardRoad_01_1.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/BollardRoad_01_1.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vegetation/FirDouglas_01_Stump.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vegetation/FirDouglas_01_Stump.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/JohnDeere_6250R_2016.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/JohnDeere_6250R_2016.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=JohnDeere_6250R_2016_Wheel_FL.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/JohnDeere_6250R_2016_Wheel_FL.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=JohnDeere_6250R_2016_Wheel_FR.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/JohnDeere_6250R_2016_Wheel_FR.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=JohnDeere_6250R_2016_Wheel_BL.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/JohnDeere_6250R_2016_Wheel_BL.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=JohnDeere_6250R_2016_Wheel_BR.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/JohnDeere_6250R_2016_Wheel_BR.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Scania_R730_2010_03+Trailer_07.obj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_R730_2010_03+Trailer_07.obj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Scania_R730_2010_03.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_R730_2010_03+Trailer_07.obj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_R730_2010_03.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Scania_Trailer_07.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_R730_2010_03+Trailer_07.obj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_Trailer_07.mobj
StdoutProtocolHandler ::oo::Obj486: #vert=3020 #norm=3939 #tex=147 #facets=3292 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=2200 #norm=2185 #tex=154 #facets=2388 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=230 #norm=173 #tex=396 #facets=454 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=940 #norm=100 #tex=619 #facets=1484 #mat=5 #usemat=5
StdoutProtocolHandler ::oo::Obj486: #vert=940 #norm=100 #tex=623 #facets=1480 #mat=5 #usemat=5
StdoutProtocolHandler ::oo::Obj486: #vert=212 #norm=68 #tex=245 #facets=326 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=10130 #norm=13481 #tex=4551 #facets=16155 #mat=12 #usemat=12
StdoutProtocolHandler ::oo::Obj486: #vert=1738 #norm=2117 #tex=311 #facets=2701 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=25 #norm=25 #tex=35 #facets=40 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: #vert=17 #norm=17 #tex=27 #facets=24 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: #vert=23744 #norm=25242 #tex=300 #facets=39043 #mat=8 #usemat=8
StdoutProtocolHandler ::oo::Obj486: #vert=981 #norm=1608 #tex=169 #facets=1780 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=1171 #norm=2038 #tex=169 #facets=2068 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=3369 #norm=3780 #tex=2251 #facets=4954 #mat=6 #usemat=6
StdoutProtocolHandler ::oo::Obj486: #vert=2430 #norm=785 #tex=1144 #facets=3642 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Scania_Truck_Wheel_Front.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_Truck_Wheel_Front.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Scania_Truck_Wheel_Back.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_Truck_Wheel_Back.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Scania_Trailer_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_Trailer_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/People/Worker_Male_01.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/People/Worker_Male_01.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/MB_Vito_2014_Construction.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Vito_2014_Construction.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=MB_Vito_2014_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Vito_2014_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vegetation/FirDouglas_01_Spring.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vegetation/FirDouglas_01_Spring.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/Construction/Portable_Toilet.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/Construction/Portable_Toilet.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Scania_Trailer_07.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/Construction/Broom.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/Construction/Broom.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/People/Worker_Male_04.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/People/Worker_Male_04.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/Construction/Site_Trailer.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/Construction/Site_Trailer.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vegetation/Beech_01_Stump.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vegetation/Beech_01_Stump.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/WarningTriangle_01.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/WarningTriangle_01.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vegetation/Lime_01_Stump.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vegetation/Lime_01_Stump.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vegetation/FirDouglas_01_Summer.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vegetation/FirDouglas_01_Summer.mobj
Terminal logs 3
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Buildings/SuburbanHouse_12_1St_2.mobj (road moviegeo) -nest -opt -wheels
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Buildings/SuburbanHouse_12_1St_2.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Terrain/Countryside_Tollgate.obj.gz (terrain) -nocache
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Terrain/Countryside_Tollgate.obj.gz
StdoutProtocolHandler ::oo::Obj486: unknown IPG-MOVIE-INFO key: AddMovieObj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/VW_Beetle_2012.mobj (vehicle) -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/VW_Beetle_2012.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Wheel_10S.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Wheel_10S.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/VW_Beetle_2012.Cab.mobj (vehicle component Cab) -opt
StdoutProtocolHandler ::oo::Obj486: → Optional file not found
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/VW_Beetle_2012.Plf.mobj (vehicle component Plf) -opt
StdoutProtocolHandler ::oo::Obj486: Prepare Route Veh id=2 1/1 path= testrun=Examples/BasicFunctions/Sensors/LidarRSI_Countryside
StdoutProtocolHandler ::oo::Obj486: Prepare Route VehSafe id=2 1/1 path= testrun=Examples/BasicFunctions/Sensors/LidarRSI_Countryside
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Skoda_Superb_2016_Combi_BikeRack.obj (traffic 0) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_BikeRack.obj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Accessories/BikeRack.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_BikeRack.obj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Accessories/BikeRack.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Skoda_Superb_2016_Combi.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_BikeRack.obj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/Bicycle_03_1.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_BikeRack.obj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/Bicycle_03_1.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/StreetFurniture/Bicycle_03_2.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_BikeRack.obj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/StreetFurniture/Bicycle_03_2.mobj
StdoutProtocolHandler ::oo::Obj486: #vert=202 #norm=124 #tex=142 #facets=316 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: #vert=262 #norm=204 #tex=182 #facets=436 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: #vert=302 #norm=164 #tex=362 #facets=498 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: #vert=3632 #norm=4482 #tex=3808 #facets=7018 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=16477 #norm=20068 #tex=1311 #facets=27267 #mat=13 #usemat=13
StdoutProtocolHandler ::oo::Obj486: #vert=1489 #norm=1647 #tex=270 #facets=2602 #mat=4 #usemat=4
StdoutProtocolHandler ::oo::Obj486: #vert=1100 #norm=1100 #tex=120 #facets=1158 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=111 #norm=66 #tex=179 #facets=208 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: #vert=89 #norm=73 #tex=8 #facets=142 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=3061 #norm=3543 #tex=3064 #facets=5830 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=2221 #norm=1092 #tex=221 #facets=3621 #mat=6 #usemat=6
StdoutProtocolHandler ::oo::Obj486: #vert=25 #norm=25 #tex=36 #facets=40 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: #vert=142 #norm=84 #tex=356 #facets=272 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=29 #norm=29 #tex=44 #facets=48 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: #vert=914 #norm=613 #tex=1274 #facets=1580 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=24431 #norm=33642 #tex=0 #facets=38989 #mat=17 #usemat=17
StdoutProtocolHandler ::oo::Obj486: #vert=1859 #norm=2437 #tex=0 #facets=3290 #mat=4 #usemat=4
StdoutProtocolHandler ::oo::Obj486: #vert=302 #norm=143 #tex=12 #facets=532 #mat=5 #usemat=5
StdoutProtocolHandler ::oo::Obj486: #vert=12928 #norm=15314 #tex=679 #facets=20992 #mat=19 #usemat=19
StdoutProtocolHandler ::oo::Obj486: #vert=1784 #norm=1173 #tex=570 #facets=2738 #mat=4 #usemat=4
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Skoda_Superb_2016_Combi_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Geely_Emgrand_Boyue_2016.mobj (traffic 1) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Geely_Emgrand_Boyue_2016.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Geely_Emgrand_Boyue_2016_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Geely_Emgrand_Boyue_2016_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Skoda_Superb_2016_Combi_RoofBox.obj (traffic 2) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_RoofBox.obj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Skoda_Superb_2016_Combi.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_RoofBox.obj) -nest
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Accessories/RoofBox.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Skoda_Superb_2016_Combi_RoofBox.obj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Accessories/RoofBox.mobj
StdoutProtocolHandler ::oo::Obj486: #vert=1923 #norm=1976 #tex=278 #facets=2871 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=15089 #norm=16813 #tex=1360 #facets=25982 #mat=15 #usemat=15
StdoutProtocolHandler ::oo::Obj486: #vert=1449 #norm=2165 #tex=391 #facets=2576 #mat=4 #usemat=4
StdoutProtocolHandler ::oo::Obj486: #vert=230 #norm=275 #tex=0 #facets=416 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Scania_R730_2010_02.mobj (traffic 3) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Scania_R730_2010_02.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/VW_T6_2016.mobj (traffic 4) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/VW_T6_2016.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=VW_T6_2016_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/VW_T6_2016_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/MB_Actros_1996.mobj (traffic 5) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Actros_1996.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=MB_Actros_1996_Cab.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Actros_1996.mobj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Actros_1996_Cab.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=MB_Actros_1996_Cab.Cab.mobj (included:/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Actros_1996.mobj) -nest
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Actros_1996_Cab.Cab.mobj
StdoutProtocolHandler ::oo::Obj486: #vert=3369 #norm=2877 #tex=2251 #facets=4954 #mat=6 #usemat=6
StdoutProtocolHandler ::oo::Obj486: #vert=13159 #norm=15857 #tex=482 #facets=20421 #mat=13 #usemat=13
StdoutProtocolHandler ::oo::Obj486: #vert=1484 #norm=2303 #tex=266 #facets=2744 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=1576 #norm=1886 #tex=0 #facets=2395 #mat=8 #usemat=8
StdoutProtocolHandler ::oo::Obj486: #vert=3166 #norm=4541 #tex=0 #facets=5105 #mat=5 #usemat=5
StdoutProtocolHandler ::oo::Obj486: #vert=0 #norm=0 #tex=0 #facets=0 #mat=0 #usemat=0
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=MB_Antos_2012_WheelFront.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Antos_2012_WheelFront.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=MB_Antos_2012_WheelBack.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Antos_2012_WheelBack.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Honda_Ridgeline_2016.mobj (traffic 6) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Honda_Ridgeline_2016.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Honda_Ridgeline_2016_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Honda_Ridgeline_2016_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Audi_A4AllRoad_2016.mobj (traffic 7) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Audi_A4AllRoad_2016.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Audi_A4AllRoad_2016_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Audi_A4AllRoad_2016_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Trailer_Scania_02.mobj (traffic 8) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Trailer_Scania_02.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/MB_Actros_Trailer.mobj (traffic 9) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MB_Actros_Trailer.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=MAN_TGS_2012_Wheel_Back.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/MAN_TGS_2012_Wheel_Back.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=3D/Vehicles/Trailer_Car_2Axle_Cover.mobj (traffic 10) -opt -wheels -lights
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Trailer_Car_2Axle_Cover.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=Trailer_Car_2Axle_Wheel.mobj (wheel) -nest -opt
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Trailer_Car_2Axle_Wheel.mobj
StdoutProtocolHandler ::oo::Obj486: LoadGeo FName=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Accessories/TrailerHitch.mobj ()
StdoutProtocolHandler ::oo::Obj486: → fullpath=/opt/ipg/carmaker/linux64-11.0.1/Movie/3D/Vehicles/Accessories/TrailerHitch.mobj
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#0 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#1 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#2 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#3 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#4 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#5 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#6 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#7 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#8 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#9 / 11
StdoutProtocolHandler ::oo::Obj486: Preparing Trf#10 / 11
StdoutProtocolHandler ::oo::Obj486: >>> Prepare Traffic <<<
StdoutProtocolHandler ::oo::Obj486: Named Movable : 0 1 2 3 4 5 6 7 8 9 10 + animated
StdoutProtocolHandler ::oo::Obj486: Named Static : + animated
StdoutProtocolHandler ::oo::Obj486: No Name Fixed : 0
StdoutProtocolHandler ::oo::Obj486: ------------------------------+
StdoutProtocolHandler ::oo::Obj486: RSI Sensors for GPUSensor #1 |
StdoutProtocolHandler ::oo::Obj486: -------------±--------±---------±----------------------------
StdoutProtocolHandler ::oo::Obj486: Type | Name | Instance | For this GPUSensor instance
StdoutProtocolHandler ::oo::Obj486: LidarRSI LIRS00 1 yes
StdoutProtocolHandler ::oo::Obj486: #vert=1610 #norm=1123 #tex=354 #facets=2714 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=1125 #norm=1107 #tex=354 #facets=1862 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=15699 #norm=17976 #tex=892 #facets=26290 #mat=17 #usemat=17
StdoutProtocolHandler ::oo::Obj486: #vert=1438 #norm=1647 #tex=479 #facets=2526 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=19154 #norm=20563 #tex=899 #facets=31450 #mat=20 #usemat=20
StdoutProtocolHandler ::oo::Obj486: #vert=1580 #norm=1979 #tex=513 #facets=2862 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=1357 #norm=456 #tex=795 #facets=2494 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=10914 #norm=2124 #tex=0 #facets=18408 #mat=7 #usemat=7
StdoutProtocolHandler ::oo::Obj486: #vert=699 #norm=583 #tex=219 #facets=1134 #mat=3 #usemat=3
StdoutProtocolHandler ::oo::Obj486: #vert=1847 #norm=1270 #tex=1297 #facets=3176 #mat=4 #usemat=4
StdoutProtocolHandler ::oo::Obj486: #vert=830 #norm=674 #tex=243 #facets=1488 #mat=2 #usemat=2
StdoutProtocolHandler ::oo::Obj486: #vert=194 #norm=189 #tex=0 #facets=384 #mat=1 #usemat=1
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Using “NVIDIA GeForce RTX 3060 Laptop GPU”
StdoutProtocolHandler ::oo::Obj486: GPUSensor_1_0@ugrdv-VirtualBox → using CUDA device #0
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Expecting 27 models
StdoutProtocolHandler ::oo::Obj486: FBB - Static geometry:
StdoutProtocolHandler ::oo::Obj486: Road = 116
StdoutProtocolHandler ::oo::Obj486: Road-DecoNoS = -1
StdoutProtocolHandler ::oo::Obj486: Road-Shadows = 115 15
StdoutProtocolHandler ::oo::Obj486: Road-BumpsNoS = -1
StdoutProtocolHandler ::oo::Obj486: Terrain = 119
StdoutProtocolHandler ::oo::Obj486: BgGeo = -1
StdoutProtocolHandler ::oo::Obj486: Puddles = -1
StdoutProtocolHandler ::oo::Obj486: TrfSigns = 45
StdoutProtocolHandler ::oo::Obj486: TrfStaticList =
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 0 initialized with 321568 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 1 initialized with 38993 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 2 initialized with 3290 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 3 initialized with 27014 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 4 initialized with 2871 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 5 initialized with 26218 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 6 initialized with 2576 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 7 initialized with 21420 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 8 initialized with 2871 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 9 initialized with 4962 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 10 initialized with 316 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 11 initialized with 436 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 12 initialized with 20425 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 13 initialized with 2744 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 14 initialized with 7508 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 15 initialized with 2714 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 16 initialized with 1862 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 17 initialized with 26302 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 18 initialized with 2526 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 19 initialized with 31462 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 20 initialized with 2862 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 21 initialized with 2496 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 22 initialized with 498 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 23 initialized with 18410 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 24 initialized with 1134 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 25 initialized with 3178 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Geometry 26 initialized with 1488 triangles
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Working directory = “/home/joe/test_project_1”
StdoutProtocolHandler ::oo::Obj486: RSIAPI::TestRun filename = “Examples/BasicFunctions/Sensors/LidarRSI_Countryside”
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Initializing lidar for graphics device 0 on MovieID 1
StdoutProtocolHandler ::oo::Obj486: RSIAPI::Received LidarRSI config message
StdoutProtocolHandler ::oo::Obj486: terminate called after throwing an instance of ‘std::runtime_error’
StdoutProtocolHandler ::oo::Obj486: what(): CUDA Error cudaErrorUnknown (unknown error)
Hello Rachel,
Thank you so much for the logs.
It is highly likely that you are using the Wayland display protocol in Ubuntu as it is the default standard in 22.04:
My colleague in Germany has suggested that you go through this process and try to switch to X11 Server instead of Wayland:
Hey Bogomil,
The computer was actually already in X11 but I did try switching back to Wayland as well.
Unfortunately, no success :frowning:
there is a known bug which will be fixed with CM 13 (Release in October)
Hey Josef,
Is there a typo in the mention of the bug fix being with CM 13 which is next year? Shouldn’t it be CM 12 for this year October instead? if yes when can we expect CM 12 to become accessible since the installation page still shows version 11.0.1?
