I’m experiencing an issue when trying to export my road model to an .xodr file in CarMaker. The export fails with an error related to a junction, and several warnings appear regarding elevation profiles and unmatched traffic signs. I’d appreciate any help or suggestions to resolve this.
Here are the details from the log:
[Error] Exporting road definition to file ‘Hauptbahnhof_model_final.xodr’ failed: Failed to split Junction entry from Link start (object 2486 )
[Warning] Failed to add ‘elevationProfile’ record of connecting road (object 6324 )
[Warning] Failed to add ‘elevationProfile’ record of connecting road (object 6327 )
[Warning] Failed to add ‘elevationProfile’ record of connecting road (object 15116 )
[Warning] Failed to add ‘elevationProfile’ record of connecting road (object 15121 )
[Warning] Failed to add ‘elevationProfile’ record of connecting road (object 15126 )
[Warning] Failed to add all items in the Junction entry of the Link end (object 1069 )
[Warning] No matching signal for traffic signs: [Warning] type ‘NoStopping’: object 18697
[Warning] type ‘NoParking’: object 18694
[Warning] type ‘Shortparkzoneover’: object 18695 [Warning] type ‘Shortparkzone’: object 20359
Hi @tolker ,
the export to .xodr format could be limited due to a number of factors. Please have a look at the limitations in User’s Guide under Scenario Editor → …→ Export to road file. Here all the limitations (not only from CarMaker side but also OpenDrive) are listed. It could be that the junction you built is not defined in OpenDrive.
If you still think the exporter should have converted the file to .xodr, then could you send the road file here?
Thank you for your reply. I don’t think my issue is related to the general limitations. Traffic signs can be handled, but the real problem occurs when I try to fix or remove errors in the road file. After making changes and attempting to export the file, I receive the following error message:
@tolker ,
the error message (and your description of reproducibility) is unfortunately too generic to troubleshoot remotely. What do you mean fix or remove errors in the road file? Could you send the road file here?
Also, CarMaker 11 is outdated. I encourage you to use newer versions which are more robust.
