Weight distributiom
How do you set up weight distribution in carmaker?
Hi Enigma! I hope you are ok
The weight distribution will be function of where you set all the vehicle masses.
When you open the vehicle in CarMaker (Main GUI → Parameters → Car), you can see and “info” button that gives you some information of the entire vehicle (axle front and rear included)
You can define your masses in the Vehicle data set:
  • Under BodyTab → Structure
  • Under Assembly Tab → Chassis, Powertrain, Trim Load
You can find more information in the User’s Guide (Main GUI → Help → User’s Guide) under the section “Vehicle Model”.
I hope it helps.
Best Regards
