I want to validate my model using IPG truckmaker. The test case is : The Relation Between inner and Outer Road Wheel During Steering Wheel Rotation and to Check its Accuracy. Suggest me how to perform this test case
Good morning, you would need to start from the vehicle generator and input to the virtual model as many accurate parameters you have from the real vehicle.
You would need to run some simulations like constant radius tests already available in CM and then compare the results using IPG control, sim vs exp.
How to define suspension and steering geometry parameters in the Kinematics Linear 3 DOF model in IPG truckmaker.
Also, if possible, can you tell me what the meaning of these parameters in the attached file is.
I want to understand if I am having K&C data graph how to feed that data like: Toe, Caster, Camber, Kingpin inclination angle into IPG using the table attached in the image.
