Using cm4sl with CMRosIF
Hi all,
I am using ROS2 Humble, CarMaker 14.0, and MATLAB 2023b. I want to use CarMaker with Simulink through cm4sl while also utilizing CarMaker with CMRosIF functionality. However, I am facing many issues and have not been able to use it. If you have used it, could you provide a solution?
Hi Kim. My name is Kim too. If you explain exactly what you mean by the question and what you want to do with examples, I think someone kind here can give you an answer. I’ve used the CM4SL environment, but I don’t think I can give you the answer you want because I haven’t used it in an environment like ros humble. I hope you have a good study.
