Testing different Front and Rear Suspension Options using TestManager
Hello
I am trying to test all of the different Front and Rear Suspension Options like the camber and toe configurations and find the optimal setup which gives the fastest lap time using test manager throughout all events. Is there a way in which I can achieve this as this will save a lot of time.
Thanks in advance
Hamedur
Hi Hamedur,
You can write scripts, use TestManager or a combination of both in case that you want to do more complex work. For the last bit, have a look in the Manual (Help->User’s Guide-> Test Automation) to the ScriptControl with StartProc and EndProc
There is also this webinar that might be helpful
Good luck in the competition.
Jose
