Test automation issue by using TargetLink
I am using CM for Simulink and I want to use a tool chain update by switching from Matlab 2020b and CM 10.2.2 to Matlab 2022b, Targetlink 22.1P6_1176457 and CM 13.1.2. After updating all Stuffs and run the simulation I have seen that some tests that are defined in the TestManager will be skiped an does not run clean. After making a lot of investigations for root cause I come to the situation that by deactivating of TargetLink (Model only) all the tests from the TestManager will be executed without any issue.
Has anybody any idea what is going wrong?
Many thanks in advance!
