I was trying to import my own car parameters but when I import the skc file from IPG kinematics, I keep on getting the Suspension knc error. As per my observation I think it would be related to the co- ordinate system. Can any one help me with it. I have used a double wishbone system with pushrod situated on the upper wishbone.
Take a look at my previous answer to a similar question:
Maybe try to provide some graphs of your skc data to see where the problem is.
Sure sir,
I have attached the skc file along with the image of graph.
Front 2024 1.0_front.skc (109.1 KB)
So, the first error tells me that your suspencion is bottoming out. You can either shorten the range in IPGKinematics a little so that this point is not calulated. Or just change the value of (0,13) to by a very small amput (e.g. -0.0181220)
Yes sir, I tried changing the geometry points by small amount but the error still persists.
Sir can the torsion bar parameters be affecting the spring parameters? Because I am quiet confused regarding the torsion bar terms as we are using a z- anti roll bar. Could you also please explain what these terms are exactly.
For all other errors. it looks like your spring mounting is somehow backwards.
Hi Sam,
May I know How did you create this graph from the SKC file?
Hello @Hugo ,
I have the same errors in my model as yours. I was wondering if you found a solution for the errors and if you can share it.
Thank you a lot!
