Hello! I’m adding the LiDAR RSI and Camera RSI sensors to our car model. However, when I start our simulation in IPG movie, the LiDAR experiences an error and I’m unable to view a pointcloud when opening a preview in the sensor’s window. Any advice on how to sort out this issue? Thanks!
Hi MFEdriverless,
Not sure what can cause the issue but I have a few questions.
- What CM version are you using?
- What Graphic card do you have? You can check minimum requirement on the Release notes, in the main CM GUI then Help → Release Notes.
- Also, have you tried to run some of the CM examples with LidarRSI. Do they work?
