I want to integrate my own made battery from Simulink to CM but I have tried several times with different methods and I can’t get it. I have a battery model in Simulink and want to integrate it with CM, how should I go about it and be able to do it. Should one make it FMI/FMU file and then integrate or what is the best way. I have tried with FMI/FMU file but also got a lot of problems there. I would have liked clear instructions on how to integrate it.
thanks in advance
Good afternoon,
you can connected the signals at the powertrain level
or better is to use a CarMaker plug in model as described in section 8.3 of the programmers guide
There are already some built examples like the
MyBattery_RTW.mdl
in the src folder of your project folder.
if you don’t have displayed that folder make sure you update the project folder
Hey, thank you for fast answer. I have tried with the FMU but when I generate the code, with simulink coder i get this error
Do I need to change the model here as well to the generated FMU?
Could you pleas describe the steps in this case and what should I change in this case ?
Hi, if you open FMU plug-in it should appear here
Thank you, but how do I solve this problem.
Do I even need to generate code from Simulink coder ?
