How to introduce a string to a named value in the Test Manager?
I’m trying to insert a named value in the Test Manager for a sign, “Minimum Speed”. But I’m not sure how to do it, I’ve tried:
  • Minimum Speed
  • (Minimum Speed)
  • “Minimum Speed”
  • $(Minimum Speed)
None of those worked.
So in short, how do I insert a string named value to modify a Road Scenario? More specifically a Sign in in the scenario?
Thanks in advance.
Best Regards,
Raúl Kevin Viana
I think the answer lies somewhere in section 14.5 of the UserGuide.pdf
In CarMaker there are two main types of variables that can be used for test automation:
  • Named Values: which can vary parameters in the GUI
  • Key Value: which can vary parameters in the infofile
I am assuming that using a Named Value is the correct choice for your case, since it is the most common type. Could you explain or take a screenshot of where you are trying to place this Named Variable?
The correct format for Named Values can be seen below. Where the first example is for a Floating number and the second is for a character.
Furthermore, Named values can also be used in combination with Realtime Expression.
So, my guess then is that the correct format for you variable is:
$Minimum_Speed
Optionally, you could also add a default value
$Minimum_Speed=30
Thanks for taking your time to answer my question.
Going into the details of what I’m trying to achieve; I’m trying to change a road sign through a Named Value. To do that I created Named Value for the road sign in the Scenario Window. The problem I’m having is that when I try to assign a specific sign through the Test Manager window, the sign doesn’t change. My question is: How can I change it? What do I write in the Value column in the Test Manager to change the sign in the Scenario?
Thanks again for your time.
Best Regards.
Raúl Kevin Viana
I have prepared a small example (CarMaker 10), where I change the displayed Speed Limit on the Traffic signs by Test Manager:
Forums_323.zip (67.5 KB)
The parameters that need to be changed can be seen in the picture below:
Please be aware that changing the traffic signs does not influence the driving speed. This can be implemented by a Marker as seen in the picture below:
Hello Alejandro,
Maybe I wasn’t clear in what I’m trying to do. I’m not trying to change the value of a Speed Limit sign, I’m trying to completely change the sign. For instance, from a Stop Sign to a Tunnel Sign.
In this example, I assigned a Named Value to the type of sign entry. It is in yellow, in the right tab. Now I want to change the sign type. I did everything similar from what you described, but my problem is what should I write in the Value column in the Test Manager to change the sign.
Best Regards.
Raúl Kevin Viana
  • Named Value: which can vary parameters in the GUI
Since I am not able to set a Named Value (NValue) in the GUI (e.g. $MyValue=50) that tells me that I need to use the other type of variable, Key Value (KValue). To show how to do it properly, I have updated the example:
Forums_323.zip (85.1 KB)
In order to figure out what the KValue names and values are, I can save a dummy test run, where I have changed the type of sign (e.g. Sign_Stop, Sign_Tunnel). This TestRuns are not needed, but they help one to find out the correct naming. Please note, that a combination of KValues and NValues can be used.
The parameters needed for each variation can be seen in the pictures below:
Please mark this reply as the Solution if you find it satisfactory.
2022-10-11_08h23_37
Also, don’t forget to ask , and also answer more questions in the forum!
This solves my problem!
Thanks for the help.
Raúl Kevin Viana
