Is it possible to cut a road inserted with a .bin file, to insert an intersection?
If it’s not possible, how can I insert and modify, on Carmaker, a route for which I know the real points obtained with GPS detection?
which CM version are you using?
I use CM 11
from CM12 you can convert a segment into 2D points, therefore you can convert the road and create road sections.
In CM11 what you can do is adding the intersection for example like I did below with a straight segment+ virtual junction that connects to the .bin file (in the example Examples/Measured/Scenario/CHE_BerninaPass.bin)
Hope this clarifies your query.
It’s so clear.
Is there an easy way to convert .bin file in a .xodr file whit out use CM?
