I was wondering if i need to keep doing a new driver adaptation after I change camber, Caster, Toe angle values?
Hi Enigma,
That depends of how your vehicle is affected from those changes. So you need to make that call. A minor change of the vehicle which has a limited impact on its dynamical behavior does not require a new adaption. However if you make a change that has a big impact, for example changing tyres, a new adaption would be required.
You can find more useful information about the Driver Adaption and the IPGDriver in its manual (Main GUI → Help → IPG Driver)
Best Regards
