I try to create a Direct Suspension in IPGKinematics, but I face some problems. First of all, there is no rocker and no stabilzer. I select None for Stabilizer Bar Fixing and Pull-/Pushrod Fixing (because there is actually none), I select Upper Wishbone for Spring Fixing, and then I start fillling the Geometry. Of course I there no Coordinates for all the Rocker-Stabilizer things so the CarMaker generates errors (35 to be exact). I don’t really now what to do and I believe that I have made the correct model. Anybody that has tried something close to my model and succed? Please contact me and I can even share my .kin and .skc file if needed.
Thank you for your help!
I am still searching for a solution. Is there anyone that knows which is the correct method to create a Direct suspension? What exactly should I do with the fixings and what with the Coordinates that do not actually exists.
