I am simulating a car going over a speed breaker at different speed and different attacking angles. Is it possible to change the attack angle without modifying the scenario so that I can use test manager to run all the test at once?
And when the car jumps over the speed breaker I am facing this “pitch angle too high error” Is there a way to suppress this error message?
- No, you would need to build a scenario for each road gradient, you can then use the test manager to run each of the test runs (vehicle+manouvre+Scenario) in sequence
- The error message is displayed because the vehicle with its suspension configuration leaves the road and/or jumps from the change of gradient you are introducing. Please check in IPG movie what is happening to make sure you are introducing a scenario with realistic configuration
