Hello, I was trying to check if we could use the shared FS autonomous project in a windows system which has a working ROS2 installed in it. In order to run the bash file the developer option in the windows file was enabled and I am able to run the bash file as well. But when trying to run the build.sh 2 file I get the following error. Can you help me with it. I have already changed the directory inside the make file in the project folder to the C:/IPG/carmaker/win64-11.0.1/include/MakeDefs.win64.
I also tried comparing the files in linux based system and windows system but however could not find any difference apart from the directory which has been changed as per windows.
