How to integrate 3D model of a car in library into your custom vehicle model.
this information wrtiten in the IPGmovie.pdf but it dows not work.
I need to translate 3D model with respect to front and rear axle positions of uservehicle.
for example: 3D/Vehicles/CUPRA_Formentor_TSI_2022.mobj
there is CUPRA_Formentor_TSI_2022.objinfo but modification of this file does not work.
6
BEGIN IPG-MOVIE-INFO
Translate 2.05 0 0.61
Scale 0.0258 0.0262 0.0256
Rotate 90 0 0 1
Rotate 90 1 0 0
Include front.obj
END IPG-MOVIE-INFO
Thank you for the ideas & help !
you can modify the example vehicles, but there are a few things you should consider:
- it´s better to modify them in your project folder, not in the installation folder → Copy & paste it in your project´s Movie folder
- .mobj files are encrypted files, therefore you shouldn´t modify them directly
- to modify a .mobj file, create your own .obj file and include the .mobj file in it (have a look at the MB_Actros_1996+Trailer.obj file from our examples, maybe this will already help you)
- don´t forget to select your .obj file as the vehicle´s outer shell (Vehicle Data Set > Tab Body > Outer Shell)
