# GPU-Sensors 1: Error: Timeout during startup
**URL:** <https://forums.ipg-automotive.com/t/gpu-sensors-1-error-timeout-during-startup/984>\
**Category:** Uncategorized\
**Created:** [23 June 2024 11:20 UTC](https://forums.ipg-automotive.com/t/gpu-sensors-1-error-timeout-during-startup/984 "2024-06-23T11:20:33Z")\
**Posts on this page:** 1\
**Showing post:** 2
<div class="post-metadata">
**Author:** ![bogomil.shtarkalev](https://forums.ipg-automotive.com/letter_avatar_proxy/v4/letter/b/8dc957/32.png) [@bogomil.shtarkalev](https://forums.ipg-automotive.com/u/bogomil.shtarkalev)\
**Post date:** [27 June 2024 08:03 UTC](https://forums.ipg-automotive.com/t/gpu-sensors-1-error-timeout-during-startup/984/2 "2024-06-27T08:03:04Z")
</div>
Hello,
Could you go through the two steps outlined in this post:
> [@One or more GPUSensors not ready in time](https://forums.ipg-automotive.com/t/one-or-more-gpusensors-not-ready-in-time/423/9):
> Hello Rachel, I spoke to my colleague in Germany who usually deals with GPU issues. He has two suggestions. First, we need to test CarMaker without all the ROS stuff. I expect the problem is with the GPU libraries and integration, but I can only be sure if we test with pure CarMaker. Go to your CarMaker installation folder and find the “CM” executable file. If you have installed CarMaker in the default path, then the default location of the executable is here: “/opt/ipg/carmaker/linux64-11.0…
1. Run the LidarRSI\_Countryside with pure CarMaker, no ROS.
2. Run CarMaker again with the -debug flag and share the output of the terminal
Thanks,
Bogomil
_[View the full topic](https://forums.ipg-automotive.com/t/gpu-sensors-1-error-timeout-during-startup/984)._
